Using Auto Pause
You can use the Auto Pause® feature to pause the timer automatically when you stop moving or when your speed drops below a specified value. This feature is helpful if your ride includes stop lights or other places where you need to slow down or stop.
NOTE: History is not recorded while the timer is stopped or paused.
  1. Select Menu symbol > Activity Profiles.
  2. Select a profile.
  3. Select Auto Features > Auto Pause.
  4. Select an option:
    • Select When Stopped to pause the timer automatically when you stop moving.
    • Select Custom Speed to pause the timer automatically when your speed drops below a specified value.
  5. If necessary, customize optional time data fields (Adding a Data Screen).
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
