Viewing Your Time in Each Training Zone
Before you can view your time in each training zone, you must pair your device with a compatible heart rate monitor or power meter, complete an activity, and save the activity.
Viewing your time in each heart rate and power zone can help you adjust your training intensity. You can adjust your power zones (Setting Your Power Zones) and your heart rate zones (Setting Your Heart Rate Zones) to match your goals and abilities. You can customize a data field to display your time in training zones during your ride (Adding a Data Screen).
  1. Select Menu symbol > History > Rides.
  2. Select a ride.
  3. Select an option:
    • If your ride has data from one sensor, select Time in HR Zone or Time in Power Zone.
    • If your ride has data from both sensors, select Time in Zone, and select Heart Rate Zones or Power Zones.
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
