You can transfer courses, segments, and workouts wirelessly from one compatible
Edge® device to another using
Bluetooth® technology.
Turn on both
Edge devices, and bring them within range (3 m) of each other.
From the device that contains the files, select
NOTE:
The
Device Transfers menu may be in a different location for other
Edge devices.
Select a file type to share.
Select one or more files to transfer.
From the device that receives the files, select
Select a nearby connection.
Select one or more files to receive.
A message appears on both devices after the file transfer is complete.
