Pairing Your Smartphone
To use the connected features of the Edge® device, it must be paired directly through the Garmin Connect™ app, instead of from the Bluetooth® settings on your smartphone.
  1. From the app store on your smartphone, install and open the Garmin Connect app.
  2. Hold Power symbol to turn on the device.
    The first time you turn on the device, you will select the device language. The next screen prompts you to pair with your smartphone.
    TIP: You can swipe down on the home screen to view the settings widget, and select Phone > Pair Smartphone to manually enter pairing mode.
  3. Select an option to add your device to your Garmin Connect account:
    • If this is the first device you have paired with the Garmin Connect app, follow the on-screen instructions.
    • If you have already paired another device with the Garmin Connect app, from the Menu symbol or Menu symbol menu, select Garmin Devices > Add Device, and follow the on-screen instructions.
    NOTE: Based on your Garmin Connect account and accessories, your device suggests activity profiles and data fields during setup. If you have sensors paired with your previous device, you can transfer them during setup.
After you pair successfully, a message appears, and your device syncs automatically with your smartphone.
Copyright © Garmin. All rights reserved.GUID-491A67EB-D2DE-4740-887D-83170BF80560 v8
