Customizing the Widget Loop
You can change the order of widgets in the widget loop, remove widgets, and add new widgets.
  1. Select Menu symbol > System > Widget Management.
  2. Select a widget to add or remove it from the widget loop.
  3. Select Rearrange the menu symbol to change the location of a widget in the widget loop.
Copyright © Garmin. All rights reserved.GUID-491A67EB-D2DE-4740-887D-83170BF80560 v8
