Using Auto Pause
You can use the
Auto Pause® feature to pause the timer automatically when you stop moving or when your speed drops below a specified value. This feature is helpful if your ride includes stop lights or other places where you need to slow down or stop.
NOTE:
History is not recorded while the timer is stopped or paused.
- Select .
- Select a profile.
- Select .
Select an option:
Select When Stopped to pause the timer automatically when you stop moving.
Select Custom Speed to pause the timer automatically when your speed drops below a specified value.
- If necessary, customize optional time data fields (Adding a Data Screen).
Parent Topic: About Training Settings
