Using the Backlight
You can tap the touchscreen to turn on the backlight.
NOTE: You can adjust the backlight timeout (Display Settings).
  1. From the home screen or a data screen, swipe down from the top of the screen.
  2. Select an option:
    • To manually adjust the brightness, select Brightness symbol, and use the slider bar.
    • To allow the device to automatically adjust the brightness based on the ambient light, select Auto.
Copyright © Garmin. All rights reserved.GUID-491A67EB-D2DE-4740-887D-83170BF80560 v8
