Tips for Installing the Device
The Varia™ eRTL615 includes a tail light and micro radar that can detect approaching vehicles up to 140 meters away.
  • Select a secure location to mount the device where it does not interfere with the safe operation of your bike.
  • Mount the device as high as possible for optimal light visibility and radar detection.
    NOTE: The mount surface should be vertical. The devices are designed to accommodate most bike rack angles.
  • Mount the device 250 mm to 1200 mm above the road.
  • Ensure the device faces backward and is perpendicular to the road.
    Diagram of the device in line with a car
  • Make sure there are no obstructions in front of the light.
  • Go for a test ride during the day in a safe environment.
GUID-FE2B50F1-79E3-4F6F-85B9-C3E5D5E56D92 v3
June 2025
