Device Overview
Device button
Press the button to check the current battery level. Each fully illuminated LED represents 25% battery power, a dimmed LED represents 12.5% battery power, and a single flashing LED represents less than 10% remaining battery power.
NOTE: The LED continues flashing until you charge the device above 10% battery power. -
When mounted, hold the button for two seconds to wake the device from sleep mode or put it into sleep mode.
When mounted, hold the button for four seconds to turn the device on or off.
System status LED
When the LED flashes a blue single-blink every 10 seconds, the device is in sleep mode. You can wake the device from the app or by moving the wheel sensor.
When the LED flashes a blue double-blink, the device radio is in active mode and available to connect using Bluetooth® and ANT+® technology.
When the LED is solid red, a system error has occurred.
During a firmware update:
When the LED flashes blue continuously, a firmware update is in transfer.
When the LED is solid or flashes purple, a firmware update is in progress.
When the LED flashes blue 10 times, a firmware update was successfully applied.
When the LED flashes red 10 times, a firmware update failed.
Battery status LEDs
While charging the battery, the LEDs light up green.
When charging is complete, the LEDs turn off.
When the battery is critically low, a single red LED flashes.
USB port
Pull up the weather cap, and plug in the USB cable to charge the Varia™ Core battery.
Pull up the weather cap, and plug in the USB cable to charge another device, such as a phone.
NOTE: You cannot use the USB port while you are using the Varia Core device on a ride. -
Replace the weather cap when charging is complete.
Battery lock lever
Snap the lever to the open position to unlock the battery.
Snap the lever to the closed position to lock the battery into the battery cradle.
