Varia eRTL615 Status LED
LED State
Status
Flashing purple
The device is in active pairing mode.
Single blue flash
The device is in smart sleep mode.
Double blue flash
The device is in active mode.
Flashing yellow
The device is in demo mode.
Flashing blue and green alternating
The device is applying a firmware update.
Flashing green 10 times
The device successfully applied a firmware update.
Flashing red 10 times
The device was unable to apply a firmware update.
Single red flash
The device is in active mode and is connected to a battery that is low.
Double red flash
The device is in smart sleep mode and is connected to a battery that is low.
Solid green
The device is in mass storage mode.
Solid red
An error occurred. You may need to restart the device.
GUID-FE2B50F1-79E3-4F6F-85B9-C3E5D5E56D92 v3
June 2025
