Installing the Device on a Seat Mount
Before you can install the Varia™ eRTL615 tail light, you need 3 mm and 4 mm hex keys and a cable to connect your device.
  1. Attach the friction flange adapter Callout number 1 to your Varia eRTL615 tail light using two M4 screws.
  2. Using a 3 mm hex key, tighten the two M4 screws to 1 N-m (9 lbf-in.).
  3. If you have other attachments on the back of your seat, attach the extender Callout number 2 to the friction flange adapter using an M5 screw.
    Exploded view with callouts and arrows
  4. Align the hole in the friction flange adapter or the extender with the hole in the center of the seat mount bracket.
  5. Attach the device to the seat mount bracket loosely using an M5 screw.
    NOTE: The M5 screw will be fully tightened after positioning the device on your bike.
  6. Attach the bracket Callout number 3 to the rails under the seat.
    Exploded view of the seat mount
  7. Using a 4 mm hex key, tighten the two M5 screws on the bracket to 2 N-m (18 lbf-in.).
  8. Position the device (Tips for Installing the Device).
  9. Using a 4 mm key, tighten the M5 screws on the friction flange adapter and extender to 3 N-m (27 lbf-in.).
    Device mounted on the bike seat
  10. Connect the cable to your bike.
    If necessary, consult the owner's manual for your bike for additional information on connecting devices.
  11. Secure the cable so that it does not interfere with any moving parts of the bike.
GUID-FE2B50F1-79E3-4F6F-85B9-C3E5D5E56D92 v3
June 2025
