Installing the Varia RDU
NOTE: If you do not have a Varia™ RDU, you can use a compatible Edge® bike computer or the Varia app on your phone (The Varia eRTL615 and the Varia App).
You can install the device on the stem or the handlebars.
  1. Select a secure location to mount the device where it does not interfere with the safe operation of your bike.
  2. Place the rubber disk Callout number 1 on the back of the bike mount.
    The rubber tabs align with the back of the bike mount so it stays in place.
    Mount on the handlebars with callouts
  3. Place the bike mount on the bike stem.
  4. Attach the bike mount securely using the two bands Callout number 2.
  5. Align the tabs on the back of the device with the bike mount notches Callout number 3.
  6. Press down slightly and turn the device clockwise until it locks into place.
    Device mounted on the handlebars
GUID-FE2B50F1-79E3-4F6F-85B9-C3E5D5E56D92 v3
June 2025
