Pairing the Varia eRTL615 with Your Phone
The first time you connect the Varia™ eRTL615 to the Varia app on your phone, you must pair both devices. After the initial pairing, the Varia app automatically connects to the Varia eRTL615 when you open the app and the radar device is active and within range.
  1. Bring your phone within range (0.5 m) of the Varia eRTL615.
    NOTE: Stay 10 m away from other Bluetooth® sensors while pairing.
  2. On your compatible phone, enable Bluetooth technology.
  3. From the app store on your phone, install and open the Varia app.
  4. Select Pair Now.
  5. While the Varia eRTL615 is in active mode, hold the device button for 4 seconds to enter pairing mode.
    The device status LED flashes purple. The device is in pairing mode for 5 minutes or until you hold the device button for 2 seconds to exit pairing mode.
  6. Select That's Mine > Pair.
When the Varia eRTL615 is paired with your phone, the app displays the current radar status.
GUID-FE2B50F1-79E3-4F6F-85B9-C3E5D5E56D92 v3
June 2025
