Customizing the Varia Device Settings with Your Edge 1040
Before you can customize Varia™ eRTL615 settings with your Edge® 1040, you must pair the devices.
- Select .
Select an option:
Select Enable to enable the light network.
Select to verify that each light in your network is set up correctly (Testing the Light Network).
Select a light to view device information and customize each light in your network (Light Network Settings).
Parent Topic: The Varia eRTL615 and Your Edge 1040
