Light Network Settings
From the Sensors menu, select Lights, and select a paired light.
Enable
Turns on the light and allows you to control the light remotely with your Edge® bike computer. You can disable a light to disconnect it from the light network.
Light Mode
Sets the light intensity and pattern mode, or turns off the light.
NOTE: This setting is available when you select the Individual light mode setting (Light Mode Settings).
About
Displays device, software, and battery information.
Remove
Allows you to delete a paired light from the network.
GUID-FE2B50F1-79E3-4F6F-85B9-C3E5D5E56D92 v3
June 2025
