Pairing the Varia Core with a Garmin Device
  1. Insert the Varia™ Core battery into the battery cradle.
  2. Hold the device button for two seconds to enter active mode.
    The system status LED flashes a blue double-blink.
  3. Bring the compatible Garmin® device within range (3 m) of the Varia Core device.
    NOTE: Stay 10 m away from other ANT‍+® devices while pairing.
  4. On the compatible Garmin device, open the menu, and select Sensors > Add > Search All.
  5. Select your Varia Core device.
GUID-FE2B50F1-79E3-4F6F-85B9-C3E5D5E56D92 v3
June 2025
