Making an Individual Routine Call NOTE: When initiating a call from the chartplotter, if the radio does not have an MMSI number programmed, the radio will not receive call information. Select Navigation Info > Other Vessels > DSC List. Select a vessel or a station to call. Select Call with Radio. If necessary, select Channel, and select a new channel. Select Send. The chartplotter sends information about the call to the radio. On your Garmin® VHF radio, select Call. Parent Topic: Individual Routine Calls
Making an Individual Routine Call NOTE: When initiating a call from the chartplotter, if the radio does not have an MMSI number programmed, the radio will not receive call information. Select Navigation Info > Other Vessels > DSC List. Select a vessel or a station to call. Select Call with Radio. If necessary, select Channel, and select a new channel. Select Send. The chartplotter sends information about the call to the radio. On your Garmin® VHF radio, select Call. Parent Topic: Individual Routine CallsHomeDigital Selective CallingIndividual Routine CallsMaking an Individual Routine Call
