Selecting the Transducer Type
Before you can select the transducer type, you must know what kind of transducer you have.
This chartplotter is compatible with the Garmin ClearVü™ transducer as well as a range of accessory transducers including Garmin® GT transducers, which are available at www.garmin.com.
If you are connecting a transducer that was not included with the chartplotter, you may need to set the transducer type to make the sonar function properly. If the device automatically detected your transducer, this option does not appear.
- From a sonar view, select .
Select an option:
If you have a 200/77 kHz, dual-beam transducer, select Dual Beam (200/77 kHz).
If you have a 200/50 kHz, dual-frequency transducer, select Dual Frequency (200/50 kHz).
If you have another type of transducer, select it from the list.
