Sonar
When properly connected to a compatible transducer, your chartplotter can be used as a fishfinder. Different sonar views can help you view the fish in the area.
The adjustments you can make to each sonar view vary depending on the view you are in and the chartplotter model and transducer you have connected.
- Sonar Views
- Selecting the Transducer Type
- Creating a Waypoint on the Sonar Screen Using the Device Keys
- Pausing the Sonar Display
- Viewing Sonar History
- Customizing the Overlay Numbers
- Adjusting the Level of Detail
- Adjusting the Color Intensity
- Adjusting the Range of the Depth or Width Scale
- Setting the Zoom Level on the Sonar Screen
- Setting the Scroll Speed
- Sonar Frequencies
- Turning On the A-Scope
- Sonar Setup
- Sonar Recordings
