You can create and immediately navigate a route on the Navigation chart or the Fishing chart. This procedure does not save the route or the waypoint data.
From the Navigation chart or Fishing chart, select a destination.
Select
Select the location of the last turn before the destination.
Follow the onscreen instructions.
If necessary, repeat step 3 and 4 to add additional turns, working backward from the destination to the present location of your vessel.
The last turn you add should be the first turn you make, starting from your present location. It should be the turn closest to your vessel.
If necessary, select
MENU.
Select
Navigate Route.
Review the course indicated by the magenta line.
Follow the magenta line, steering to avoid land, shallow water, and other obstacles.
