Sharing Waypoints and Routes Across Devices
Before you can share waypoints and routes, you must connect the devices using a data sharing cable. The data sharing cable is an optional accessory you can purchase.
You can share waypoint and route data between two compatible chartplotters installed on your boat. You must turn on user data sharing for both devices to share data.
Select
on both devices.
Parent Topic: Chartplotter Data Management
