Manual Conventions
In this manual, the term “select” is used to describe these actions.
Using the arrow keys to highlight a menu item, and then pressing SELECT (for hard key devices only).
Pressing a key, such as SELECT or MENU.
When you are instructed to select multiple items in a series, small arrows appear in the text. For example, "select ," indicates that you need to select the MENU item or hard key and then select the Add item.
The images in this manual are for reference only and may not match your device exactly.
Parent Topic: Introduction
