Navigation Settings
NOTE: Some settings and options require additional charts or hardware.
Select Settings > Navigation.
Route Labels
Sets the type of labels shown with route turns on the map.
Auto Guidance
Sets the parameters the chartplotter uses when calculating an Auto Guidance path, when you are using some premium maps.
Turn Transition Activ.
Sets the turn transition to be calculated based on time or distance.
Turn Transition Time
Sets how many minutes before the turn that you transition to it as the next leg, when Time is selected for the Turn Transition Activ. setting. You can raise this value to help improve the accuracy of the autopilot when navigating a route or an Auto Guidance path with many frequent turns or at higher speeds. For straighter routes or slower speeds, lowering this value can improve autopilot accuracy.
Turn Transition Dist.
Sets how far before the turn that you transition to it as the next leg, when Distance is selected for the Turn Transition Activ. setting. You can raise this value to help improve the accuracy of the autopilot when navigating a route or an Auto Guidance path with many frequent turns or at higher speeds. For straighter routes or slower speeds, lowering this value can improve autopilot accuracy.
Route Start
Selects a starting point for route navigation.
Copyright © Garmin. All rights reserved.GUID-07BB0D0C-0781-43E3-BD62-8C02AFC68092 v5
