Showing Satellite Imagery on the Navigation Chart
NOTE:
This feature is available with premium charts, in some areas.
You can overlay high-resolution satellite images on the land or on both land and sea portions of the Navigation chart.
NOTE:
When enabled, high-resolution satellite images are present only at lower zoom levels. If you cannot see high-resolution images in your optional chart region, you can select
to zoom in. You also can set the detail level higher by changing the map zoom detail.
- From the Navigation chart, select .
Select an option:
Select Land Only to show standard chart information on the water, with photos overlaying the land.
Select Photo Map Blend to show photos on both the water and the land at a specified opacity. Use the slider bar to adjust the photo opacity. The higher you set the percentage, the more the satellite photos cover both land and water.
Parent Topic: Premium Charts
