Sonar Installation Settings
NOTE:
Not all options and settings apply to all models and transducers.
From a sonar view, select .
- Restore Sonar Defaults
Restores the factory default settings for the sonar view.
- Transducer Type
Allows you to select the type of transducer that is connected to the device.
- Shift
Allows you to set the depth range on which the sonar is focused. This enables you to zoom in to an area within the focused depth.
- Flip Left/Right
Changes the orientation of the SideVü sonar view when the transducer is installed backward.
Parent Topic: Sonar Setup
