My Vessel Settings
NOTE:
Some settings and options require additional charts or hardware.
Select .
- Keel Offset
Offsets the surface reading for the depth of a keel, making it possible to measure depth from the bottom of the keel instead of from the transducer location (Setting the Keel Offset).
- Temp. Offset
Compensates for the water temperature reading from a NMEA® 0183 water-temperature sensor or a temperature-capable transducer (Setting the Water Temperature Offset).
- Vessel Type
Enables some chartplotter features based on the boat type.
Parent Topic: Device Configuration
