Setting the Heading and Course Over Ground Lines
You can show the heading line and the course over ground (COG) line on the chart.
COG is your direction of movement. Heading is the direction the bow of the boat is pointed, when a heading sensor is connected.
  1. From a chart view, select MENU > Chart Setup > Chart Appearance > Heading Line.
  2. If necessary, select Source, and select an option:
    • To automatically use the source available, select Auto.
    • To use the GPS antenna heading for COG, select GPS Heading (COG).
    • To use data from a connected heading sensor, select Heading.
    • To use data from both a connected heading sensor and the GPS antenna, select COG and Heading.
      This displays both the heading line and the COG line on the chart.
  3. Select Display, and select an option:
    • Select Distance > Distance, and enter the length of the line shown on the chart.
    • Select Time > Time, and enter the time used to calculate the distance your boat will travel in the specified time at your present speed.
Copyright © Garmin. All rights reserved.GUID-07BB0D0C-0781-43E3-BD62-8C02AFC68092 v5
