Navigating to a Point on the Chart
The Auto Guidance feature is based on electronic chart information. That data does not ensure obstacle and bottom clearance. Carefully compare the course to all visual sightings, and avoid any land, shallow water, or other obstacles that may be in your path.
When using Go To, a direct course and a corrected course may pass over land or shallow water. Use visual sightings, and steer to avoid land, shallow water, and other dangerous objects.
NOTE:
The offshore Fishing chart is available with premium charts, in some areas.
NOTE:
Auto Guidance is available with premium charts, in some areas.
Parent Topic: Navigation Chart and Offshore Fishing Chart
