Navigating to Your Starting Point During an Activity
You can navigate back to the starting point of your current activity in a straight line or along the path you traveled. This feature is available only for activities that use GPS.
  1. During an activity, press STOP.
  2. Select Back to Start, and select an option:
    • To navigate back to the starting point of your activity along the path you traveled, select TracBack.
    • To navigate back to the starting point of your activity in a straight line, select Straight Line.
    Map with callouts
    Your current location Callout number 1, the track to follow Callout number 2, and your destination Callout number 3 appear on the map.
June 2025
