Tips for Charging the Watch
  1. Connect the charger securely to the watch to charge it using the USB cable (Charging the Watch).
    You can charge the watch by plugging the USB cable into a Garmin® approved AC adapter with a standard wall outlet or a USB port on your computer. Charging a fully depleted battery takes up to two hours.
  2. Remove the charger from the watch after the battery charge level reaches 100%.
June 2025
