Triathlon Training
When you participate in a triathlon, you can use the triathlon activity to quickly transition to each sport segment, to time each segment, and to save the activity.
  1. Press START.
  2. Select Triathlon.
  3. Press START to start the activity timer.
    NOTE: Auto Sport Change is the default setting for multisport activities (Activities and App Settings).
  4. If necessary, press BACK at the beginning and end of each transition (How can I undo a lap button press?).
    The transition feature is on by default, and the transition time is recorded separately from the activity time. The transition feature can be turned on or off in the triathlon activity settings. If transitions are turned off, press BACK to change sports.
  5. After you complete your activity, press STOP, and select Save.
GUID-676967A0-1B23-4384-9BC9-76F3D643F1C8 v11
December 2024
