Customizing the Glance Loop
  1. Hold UP.
  2. Select Appearance > Glances.
  3. Select an option:
    • To change the location of a glance in the loop, select a glance, and press UP or DOWN.
    • To remove a glance from the loop, select a glance, and select Delete symbol.
    • To add a glance to the loop, select Add, and select a glance.
      TIP: You can select Create Folder to create folders that contain multiple glances ( Creating Glance Folders).
June 2025
