Creating Glance Folders You can customize the glance loop to create folders of related glances. Hold UP. Select Appearance > Glances > Add > Create Folder. Select the glances to include in the folder, and select Done. NOTE: If the glances are already in the glance loop, you can move or copy them into the folder. Select or enter a name for the folder. Select an icon for the folder. If necessary, select an option: To edit the folder, scroll to the folder in the glance loop, and hold UP. To edit the glances in the folder, open the folder and select Edit (Customizing the Glance Loop). Parent Topic: Customizing the Glance Loop
Creating Glance Folders You can customize the glance loop to create folders of related glances. Hold UP. Select Appearance > Glances > Add > Create Folder. Select the glances to include in the folder, and select Done. NOTE: If the glances are already in the glance loop, you can move or copy them into the folder. Select or enter a name for the folder. Select an icon for the folder. If necessary, select an option: To edit the folder, scroll to the folder in the glance loop, and hold UP. To edit the glances in the folder, open the folder and select Edit (Customizing the Glance Loop). Parent Topic: Customizing the Glance LoopHomeAppearanceGlancesCustomizing the Glance Loop Creating Glance Folders
