Changing the Screen Settings
  1. Hold UP.
  2. Select System > Display.
  3. Select Large Fonts to increase the size of the text on the screen.
  4. Select an option:
    • Select During Activity.
    • Select General Use.
    • Select During Sleep.
      NOTE: Some options are not available during sleep.
  5. Select an option:
    • Select Keys to turn on the backlight for button presses.
    • Select Alerts to turn on the backlight for alerts.
    • Select Gesture to turn on the backlight by raising and turning your arm to look at your wrist.
    • Select Timeout to set the length of time before the backlight turns off.
    • Select Brightness to set the brightness level of the backlight.
June 2025
