Setting Up the Pro 550 Plus System
Before you can use the Pro 550 Plus system, you must set up the devices.
- Charge the handheld device (Charging the Handheld Device).
- Charge the dog collar device (Charging the Dog Collar Device).
- Turn on the devices (Turning On the Device).
- Select a language (Selecting a Language).
- If necessary, pair the dog collar device with the handheld device (Pairing a Dog Collar Device with the Handheld Device).
- If necessary, calibrate the compass on the handheld device (Calibrating the Compass on the Handheld Device).
Parent Topic: Getting Started
