Acquiring Satellite Signals
NOTE:
This device is intended for outdoor use only. Satellite reception requires a clear line of sight to the sky. GPS accuracy may be affected if you use the device indoors.
Both the dog collar device and the handheld device must acquire satellite signals before you put the dog collar device on your dog. Acquiring satellite signals can take a few minutes.
- Go outdoors to an open area.
- Turn on both devices (Turning On the Device).
- On the handheld device, select a paired collar with the toggle switch.
When the dog collar device has acquired satellite signals, the status LED flashes a double-blink or triple-blink in green. When the handheld device has acquired satellite signals and communicated with a paired dog collar device, it displays status information for the dog collar device (Handheld Device Screen).
Parent Topic: Getting Started
