Selecting a Language
NOTE:
This option is not applicable for all models.
When you turn on your device for the first time, you will set the device language.
- Use the training keys to scroll through the list of available languages.
- Press the green tone key to select your language.
- Press the top training key to confirm your selection.
NOTE:
If you need to change the language after initial language selection, you must reset the device to default settings (Resetting the Handheld Device to Default Settings).
Parent Topic: Getting Started
