Removing the Old Battery
Before you replace the battery, you must remove all dirt, water, and debris from the device. You must also have a small Phillips screwdriver.
After you remove the old battery, contact your local waste disposal department to properly recycle the battery.
Parent Topic: TT 15 Battery Replacement Instructions
