Selecting and Installing the Contact Points
For best results, select the correct contact points based on your dog's coat.
  1. Select the correct contact point length for your dog's coat type:
    • For dogs with thicker coats, use the longer contact points.
    • For dogs with shorter coats, use the shorter contact points.
  2. If necessary, use the included wrench to remove the contact points.
  3. Twist the contact points into the collar.
  4. Tighten with the included wrench, but do not overtighten.
When you put the collar on the dog, make sure the contact points are tight against the neck.
Copyright © Garmin. All rights reserved.GUID-6F59C1FE-F1F8-4AF3-9397-F68DD13DD423 v4
