Charging the Handheld Device
To prevent corrosion, thoroughly dry the USB port, the weather cap, and the surrounding area before charging or connecting to a computer.
You should fully charge the battery before you use the device for the first time or whenever the battery is low (Checking the Battery Level of the Dog Collar Device). It is normal for the battery to discharge in approximately 1 year when the device is not in use. Charging a fully depleted battery takes about 2 hours.
NOTE:
The device is fully functional while charging when using an AC power adapter. The device will not charge when it is outside the charging temperature range (Specifications - Pro Series HH).
Parent Topic: Getting Started
