My step count does not seem accurate If your step count does not seem accurate, you can try these tips. Wear the device on your non-dominant wrist. Carry the device in your pocket when actively using your hands or arms only. NOTE: The device may interpret some repetitive motions, such as clapping your hands or brushing your teeth, as steps. Parent Topic: Troubleshooting
My step count does not seem accurate If your step count does not seem accurate, you can try these tips. Wear the device on your non-dominant wrist. Carry the device in your pocket when actively using your hands or arms only. NOTE: The device may interpret some repetitive motions, such as clapping your hands or brushing your teeth, as steps. Parent Topic: TroubleshootingHomeDevice InformationTroubleshootingMy step count does not seem accurate
