Training Indoors
You can turn off GPS when you are training indoors or to save battery life. When GPS is off, speed and distance are calculated using the accelerometer in the device. The accelerometer is self-calibrating. The accuracy of the speed and distance data improves after a few outdoor runs using GPS.
Select
Select an option:
Select Run Indoor or Cardio.
Select .
Parent Topic: Setting the Run Mode
