Playing Audio Prompts During Your Activity
Before you can set up audio prompts, you must have a smartphone with the Garmin Connect™ Mobile app paired to your Forerunner® device.
You can set the Garmin Connect Mobile app to play motivational status announcements on your smartphone during a run or other activity. Audio prompts include the lap number and lap time, pace or speed, and ANT+® sensor data. During an audio prompt, the Garmin Connect mobile app mutes the primary audio of the smartphone to play the announcement. You can customize the volume levels on the Garmin Connect Mobile app.
- From the settings in the Garmin Connect Mobile app, select Garmin Devices.
- Select your device.
- Select .
Parent Topic: Garmin Connect
