Running With the Virtual Pacer Feature
NOTE:
You must set up the
Virtual Pacer™ feature before starting a run. After you start the run timer, you cannot change the settings.
Select
, and select a running profile.
- Select .
- Enter your pace.
- Go for a run.
Each time you exceed or drop below the target pace, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds). After you turn on the Virtual Pacer feature, it is used each time you go for a run until you turn it off or enable a different run mode.
Parent Topic: Virtual Pacer
