Updating the Software
Before you can update your device software, you must have a Garmin Connect™ account, and you must download the Garmin Express™ application.
  1. Connect the device to your computer using the USB cable.
    When new software is available, the Garmin Express application sends it to your device.
  2. Follow the on-screen instructions.
  3. Do not disconnect your device from the computer while the Garmin Express application downloads the software.
    TIP: If you are having trouble updating the software with the Garmin Express application, you may need to upload your activity history to the Garmin Connect application and delete your activity history from the device. This should provide sufficient memory space for the update.
Copyright © Garmin. All rights reserved.GUID-2459AAAE-5F77-485E-BCBD-39BD8A74045E v5
