Playing Audio Prompts During an Activity
You can enable your Forerunner® 645 Music device to play motivational status announcements during a run or other activity. Audio prompts play on your connected headphones using Bluetooth® technology, if available. Otherwise, audio prompts play on your smartphone paired through the Garmin Connect™ app. During an audio prompt, the device or smartphone mutes the primary audio to play the announcement.
- Hold UP.
- Select .
Select an option:
To hear a prompt for each lap, select Lap Alert.
NOTE: The Lap Alert audio prompt is enabled by default. -
To customize prompts with your pace and speed information, select Pace/Speed Alert.
To customize prompts with your heart rate information, select Heart Rate Alert.
To hear prompts when you start and stop the timer, including the Auto Pause® feature, select Timer Events.
To change the language or the dialect of the voice prompts, select Dialect.
