Data Fields
Some data fields require ANT‍+® accessories to display data.
%HRR
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
24-Hour Max.
The maximum temperature recorded in the last 24 hours.
24-Hour Min.
The minimum temperature recorded in the last 24 hours.
Aerobic TE
The impact of the current activity on your aerobic fitness level.
Anaerobic TE
The impact of the current activity on your anaerobic fitness level.
Average HR
The average heart rate for the current activity.
Average Pace
The average pace for the current activity.
Average Swolf
The average swolf score for the current activity. Your swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology). In open water swimming, 25 meters is used to calculate your swolf score.
Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Avg. Ascent
The average vertical distance of ascent since the last reset.
Avg. Cadence
Running. The average cadence for the current activity.
Avg. Cadence
Cycling. The average cadence for the current activity.
Avg. Descent
The average vertical distance of descent since the last reset.
Avg. GCT Bal.
The average ground contact time balance for the current session.
Avg. Lap Time
The average lap time for the current activity.
Avg. Speed
The average speed for the current activity.
Avg. Stride Len.
The average stride length for the current session.
Avg. Strk/Len
The average number of strokes per pool length during the current activity.
Avg. Vert. Osc.
The average amount of vertical oscillation for the current activity.
Avg. Vert. Ratio
The average ratio of vertical oscillation to stride length for the current session.
Avg GCT
The average amount of ground contact time for the current activity.
Avg HR %Max.
The average percentage of maximum heart rate for the current activity.
Battery Level
The remaining battery power.
Bearing
The direction from your current location to a destination. You must be navigating for this data to appear.
Cadence
Running. The steps per minute (right and left).
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Calories
The amount of total calories burned.
Compass Hdg.
The direction you are moving based on the compass.
Course
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
Dest. Location
The position of your final destination.
Dest. Wpt
The last point on the route to the destination. You must be navigating for this data to appear.
Dist. Remaining
The remaining distance to the final destination. You must be navigating for this data to appear.
Distance
The distance traveled for the current track or activity.
Distance To Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
Elapsed Time
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Elevation
The altitude of your current location above or below sea level.
Estimated Total Distance
The estimated distance from the start to the final destination. You must be navigating for this data to appear.
ETA
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
ETE
The estimated time remaining until you reach the final destination. You must be navigating for this data to appear.
GCT
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
GCT Balance
The left/right balance of ground contact time while running.
Glide Ratio
The ratio of horizontal distance traveled to the change in vertical distance.
Glide Ratio Dest.
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
GPS
The strength of the GPS satellite signal.
GPS Elevation
The altitude of your current location using GPS.
GPS Heading
The direction you are moving based on GPS.
Grade
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
HR %Max.
The percentage of maximum heart rate.
HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Int. Distance
The distance traveled for the current interval.
Int. Pace
The average pace for the current interval.
Int. Swolf
The average swolf score for the current interval.
Interval Lengths
The number of pool lengths completed during the current interval.
Interval Time
The stopwatch time for the current interval.
Int Strk/Len
The average number of strokes per pool length during the current interval.
Int Strk Rate
The average number of strokes per minute (spm) during the current interval.
Int Strk Type
The current stroke type for the interval.
L. Lap HR %Max.
The average percentage of maximum heart rate for the last completed lap.
L. Len. Stk. Rate
The average number strokes per minute (spm) during the last completed pool length.
L. Len. Stk. Type
The stroke type used during the last completed pool length.
L. Len. Strokes
The total number of strokes for the last completed pool length.
Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap Ascent
The vertical distance of ascent for the current lap.
Lap Cadence
Running. The average cadence for the current lap.
Lap Cadence
Cycling. The average cadence for the current lap.
Lap Descent
The vertical distance of descent for the current lap.
Lap Distance
The distance traveled for the current lap.
Lap GCT
The average amount of ground contact time for the current lap.
Lap GCT Bal.
The average ground contact time balance for the current lap.
Lap HR
The average heart rate for the current lap.
Lap HR %Max.
The average percentage of maximum heart rate for the current lap.
Lap Pace
The average pace for the current lap.
Laps
The number of laps completed for the current activity.
Lap Speed
The average speed for the current lap.
Lap Stride Len.
The average stride length for the current lap.
Lap Time
The stopwatch time for the current lap.
Lap Vert. Osc.
The average amount of vertical oscillation for the current lap.
Lap Vert. Ratio
The average ratio of vertical oscillation to stride length for the current lap.
Last Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the last completed lap.
Last Lap Ascent
The vertical distance of ascent for the last completed lap.
Last Lap Cad.
Running. The average cadence for the last completed lap.
Last Lap Cad.
Cycling. The average cadence for the last completed lap.
Last Lap Descent
The vertical distance of descent for the last completed lap.
Last Lap Dist.
The distance traveled for the last completed lap.
Last Lap HR
The average heart rate for the last completed lap.
Last Lap Pace
The average pace for the last completed lap.
Last Lap Speed
The average speed for the last completed lap.
Last Lap Time
The stopwatch time for the last completed lap.
Last Len. Pace
The average pace for your last completed pool length.
Last Len. Swolf
The swolf score for the last completed pool length.
Lat/Lon
The current position in latitude and longitude regardless of the selected position format setting.
Lengths
The number of pool lengths completed during the current activity.
Location
The current position using the selected position format setting.
Max. Ascent
The maximum rate of ascent in feet per minute or meters per minute since the last reset.
Max. Descent
The maximum rate of descent in meters per minute or feet per minute since the last reset.
Max. Elevation
The highest elevation reached since the last reset.
Maximum Speed
The top speed for the current activity.
Min. Elevation
The lowest elevation reached since the last reset.
Muscle O2 Sat. %
The estimated muscle oxygen saturation percentage for the current activity.
Next Waypoint
The next point on the route. You must be navigating for this data to appear.
Off Course
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
Pace
The current pace.
Perform. Cond.
The performance condition score is a real-time assessment of your ability to perform.
Repeat On
The timer for the last interval plus the current rest (pool swimming).
Rest Timer
The timer for the current rest (pool swimming).
Speed
The current rate of travel.
Stride Length
The length of your stride from one footfall to the next, measured in meters.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor.
Time in Zone
The time elapsed in each heart rate or power zone.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Timer
The stopwatch time for the current activity.
Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
Total Ascent
The total elevation distance ascended since the last reset.
Total Descent
The total elevation distance descended since the last reset.
Total Hemoglobin
The estimated muscle oxygen total for the current activity.
V Dist to Dest
The elevation distance between your current position and the final destination. You must be navigating for this data to appear.
Vert. Spd.
The rate of ascent or descent over time.
Vertical Osc.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
Vertical Ratio
The ratio of vertical oscillation to stride length.
Vert Spd to Tgt
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
VMG
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
Copyright © Garmin. All rights reserved.GUID-B5342B9E-4C03-4F1B-9521-73E25608AF73 v7
