The floors climbed amount does not seem accurate
Your device uses an internal barometer to measure elevation changes as you climb floors. A floor climbed is equal to 3 m (10 ft.).
  • Avoid holding handrails or skipping steps while climbing stairs.
  • In windy environments, cover the device with your sleeve or jacket as strong gusts can cause erratic readings.
Copyright © Garmin. All rights reserved.GUID-B5342B9E-4C03-4F1B-9521-73E25608AF73 v7
