Navigating to a Saved Location
Before you can navigate to a saved location, your device must locate satellites.
  1. From the watch face, select START.
  2. Select an activity.
    NOTE: This feature is not available for all activities.
  3. Hold UP.
  4. Select Navigation > Saved Locations.
  5. Select a location, and select Go To.
  6. Move forward.
    The compass arrow points toward the saved location.
    TIP: For more accurate navigation, orient the top of the screen toward the direction in which you are moving.
  7. Select START to start the activity timer.
Copyright © Garmin. All rights reserved.GUID-B5342B9E-4C03-4F1B-9521-73E25608AF73 v7
