Cable and Connection Considerations
NOTICE
A blue rubber seal is included for each DVI port on the device. This seal must be installed between each DVI port and DVI-cable connector to avoid damage to the connectors.
  • For easer cable routing, the power, NMEA® 0183, and Garmin® Marine Network cables are packaged without the locking rings installed. You should route the cables before you install the locking rings.
  • After connecting a locking ring to a cable, make sure the ring is securely connected and the o-ring is in place so the power or data connection remains secure.
  • The device should be connected to the same power source as the card reader. If this is not possible, the devices must be connected to the same ground.
GUID-A5780D3E-B2B0-4C60-8835-94BCF0D13E14 v5
January 2025
